Upgrade
I am slightly hoping that there will be a licensed replica release, but last week's Constantine showed off an intricately designed record.
It is explained as being Willie Cole's last recording before he disappeared and it gains its power from having the voice of the First of the Fallen.
I find it odd that all the characters continuously call it as an acetate, which was made from a lacquer-coated aluminum disc, yet the episode title refers to "vinyl".
I made a couple of screengrabs here.
http://imgur.com/a/aYfXo
Here are some squared up versions of the Moonrise Studios record sleeve and label.
I might try to vectorize the designs in Illustrator if the prop doesn't surface.
Moonrise Studios
Willie Cole
June 18, 1938
Most likely a 78 rpm record.
Double-Sided Electrically Recorded
Probably only one side was recorded on for obvious reasons.
Some equipment from the episode:
Most likely a Technics SL-1200 turntable. Tape is covering the RPM buttons and the logo, but "Quartz" can be discerned. Oddly, none of the speed buttons are lit up from 33 and 45 rpm. Was it modded for 78 rpm?
We get a lovely view of an RCA record cutting machine. Unfortunately I don't recognize the model.
It does look like it's an actual working machine, so they might have really recorded something on the set.
Side view of the machine, please ignore the blood.
Another record player. Tonearm is similar to the Audio Technica AT-LP60, but it's too dark to see much.
The episode should still be up for viewing at the NBC website.
You can listen to the entire song here:
"Reaper Man" sung by Martin Yarbrough
https://www.youtube.com/watch?v=ivGeuo5k84I
Moonrise Studios
Willie Cole
June 18, 1938
