Bloop
I decided to put together a Spider-Man costume for Halloween this year. I've tried dressing as other heroes in the past, but I realized that my body type is much more Spider-Man-like than Wolverine, or even Starlord. So I might as well go for it. I should also say that Spider-Man has always been a favorite of mine. I wanted to do a costume, but while I liked aspects of all the movie costumes, there isn't one single costume absolutely loved. But I found this concept art for Amazing Spider-Man 2 by Jerod S. Marantz that I really liked, and decided to try to do a version of it:
I liked each of the designs, though the one in the middle is the one I mostly went off of. It actually is pretty close to the design that ended up in the film, but it has key differences, like the larger spider, curved webs, pointed belt and boot tops, etc. I did like the split belt of the left design, and I tried it out when designing my costume, but I couldn't make it work like the concept art, so I went with the more traditional style. After toying with the idea of customizing a zentai suit or trying to piece something together from compression gear, I decided to go the dye-sub route. I used the great patterns supplied by @kenlandrum here: http://www.therpf.com/showthread.php?t=207565 http://www.therpf.com/showthread.php?t=208912 I used the Rami suit with muscle shading as the base, but I also copied the mask webs (and maybe some other design layout) from the ASM 2 file. I reversed the brick pattern from dark to light, reduced the amount of muscle shading to make it more subtle (more on that later):
Since I had to go away for work suddenly a few weeks ago, and will have to leave again soon, I opted for zentaizone to have my file printed and sewn. I read up on other custom dye-subs done by them and figured the speed, quality and cost were worth the risk. I always planned on making alterations and tweaks so I was prepared for that as well. I tweaked the CMKY colors since some of the dye-subs I've seen end up too dark or less vibrant than the supplied pattern. I went a little more bright than the concept art, figuring if it came out darker, I'd still be OK with it. I uploaded the file, gave zentaizone my measurements and requests and except for a couple snafus on my end with the uploaded pattern, the whole process was fast and painless. The suit arrived a little over a week after I ordered. I was still out of town, so I had to wait until a coupe days ago to see it. The good news is it looks and fits (for the most part) great! As I thought, the colors were slightly darker, but not too much. Though it could use some alterations in spots to really fit perfect, it is wearable as is.
Unfortunately, when I tried it on, I couldn't get my head through the neck hole! I had request the U -shape back zipper which goes from the armpits to the belt, so there was no neck zipper to open to get my head in. It might be my fault. I requested they make the neck of the suit and mask as long as possible, because I read other zentaizone reviews saying that the mask was often too short and would pull up. So maybe the longer neck meant a smaller neck hole, or it could just be my skinny neck, or the stitching limiting the stretching of the spandex. At any rate, I had to rip out some stitches, and planned to install an invisible zipper to fix it. Before installing the zipper, I was able to try it on fully.
The pics show the costume in natural daylight as well as incandescent or with flash. The natual light colors look the best.
While the colors look good, the brick pattern and muscle shading ended up being too subtle. The bricks still show up a bit on the blue parts, but are completely gone on most of the red. I did try to err on the side of too subtle, but I obviously went too far. Still, it looks good even without the extra detail, but I still wish it was there. I also added fake seam lines, which are difficult to see, but I plan to either enhance them with paint or sharpee, or (if I get ambitious) sew them into actual seams.
