Choosing the right airbrush
S
Savage Yautja
Guest
I 'd appreciate any input on choosing the right Iwata 2 stage airbrush. Considering the HP-C, HP-CS or an Eclipse model. Just too many models to pick from. Looking to use it for painting latex costumes, model kits, bio helmets, ect. Something great to use with acrylics, enamals,and inks.
Please post the one you use or would suggest and any review of what you thought of their performance.
Also plan to get a better air compressor with it at the same time if possible. Probably get a better deal that way too.Thanks!
I use alot of airbrushes each one has it own suffix uses. The iwata airbrush I use for fine detail is the iwata HP-CH. I use a paasche VL for med spay areas. I use a paasche H or the binks wren A single action for large coverage. I use an aztek airbrush just for the splatter tip. Paasche are good throw away brushes and cheap. Most of the Iwata line will work, it's how much do you want spend. Models that will fit your needs: HP-BC2, HP-CS, HP-BCS, Eclipse G6, and CM-SB
Hope this helps Mark.
this might not help a whole lot but i use an Iwata Eclipse and i absofeakenlutely Love it. Works like a charm.
KEITH
