Bungled Aluminum machining - advice needed for Amiga Lamp Project!
lucifred
Hello Guys,
I am building an Amiga Lamp... and completed most of the framing:
http://www.flickr.com/photos/86679254@N00/4433904019/in/set-72157623498401629/
http://www.flickr.com/photos/86679254@N00/4434679056/in/set-72157623498401629/
However, I screwed up while machining a side, and the little cuts I made cast ungainly shadows:
http://www.flickr.com/photos/86679254@N00/4434679538/in/set-72157623498401629/
http://www.flickr.com/photos/86679254@N00/4433903457/in/set-72157623498401629/
I could of course machine another piece, but I am interested in ways I could fill up those cuts that would still look metallic... after all, building things should be a way to learn new tricks ;)
-F
USC All-Metal or similar automotive aluminum filler might work.... I say might because I'm not sure it could be polished/brush finished to the same luster as the aluminum angle.
Have you considered maybe putting a black thin adhesive weatherstrip in that area or all the way around to kill any light leaks? That might be the cheapest <$5 solution.
The U.S. Chemical product All-Metal would work very well for filling properties, and would smooth out very well. But unfortanatly, you will not be able to get a smooth alminum finish. It would be a small but noticable repair. You could paint over it with House of Kolor Aluminum paint, but this requires alot of preperation, and a pain to work with if you don't have experiance with automotive paint.
Pardon my ignorance, but what is an "Amiga Lamp"? Is it based on an ol' Commodore Amiga motherboard? If so, I might have an added touch for you...
Eric
Wow. You have an Amiga! I wanted to do that to my 1500 but well, that was a decade ago.......
Fill it with whatever filler you want, then apply metal tape over the top?
You know, the stuff they repair ducts with- you can get a small roll at the hardware store for like, $8? You should be able to lightly sand it to match whatever finish you have on your aluminum stock (its pretty shiny to start with).
That's a great idea, actually, but I decided to use it as an excuse to practice on the Bridgeport, and machined new pieces using the hand-made ones as prototypes.
Gentlemen, I give you the Amiga Lamp (ta-daaaah!):
Amiga Lamp 2.0
