- UPDATE -
- The display is now repaired. The visible air holes filled and is flush with the surface.
- This display will be used to create a casting-mold so that I can make copy's that I can work on. Since this is the only one, I cannot afford to mess with it.
- Once I can make copy's, they will be used to create one master display.
- This master display will be adjusted so that the PCB is flush against the surface + the added ridges (moved from front) will be adjusted together with the display itself so that the clear lid is not longer or shorter than the depth of the display itself.
- Once master display is made by using parts for the copy's, final PCB will be drafted.
- When master display and PCB is constructed and checked for perfect match, new master mould will be made.
- Back plate or bracket to hold PCB place will be manufactured + mould. Possibly milled from aluminum (master).
- This bracket will be a cast resin part that will be glued to the display itself - such a solution can be seen in one of the photos published in this tread.
- Before it is clued in place, all bulbs will be tested after they've been mounted on the PCB for reinsurance of full functionality including PCB-to-back bracket pins
- Cut and place diffusion film gel sheet.
- The display should now be complete.
- Next is to manufacture the main back bracket that contain the lugs I've showed you before. The hole is 1 mm in dm and I have selected 1.2 mm pins to assure a tight fit between the display and bracket.
- This item will consist of 4 parts. 1. Plate that is facing the display. 2. Metal sheet so that the bracket can be mounted to the main aluminum frame mounted on the remote. 3. Part that contains the solder lug, the section where the pins becomes attached. 4. This part is the back lid or plate that contains 9 groves for the lug itself. The whole package will be glued and sealed. All parts need to be manufactured from scratch. Including master, mould and castings.
- Display and bracket will be assembled and tested.
- Replication of Stanley Electronics Inc - 7 segment incandescent light emitting diode display (long name) should now be complete and ready to be enjoyed.
This is all the steps involved so that everyone knows. I am also currently burdened with a huge pile if bills that I need to take care of for the next two months. I will probably not be able to afford purchasing casting silicone and resin. Technically, 2 months would be fine to complete this display, but unfortunately, the entire project has been moved equal amount of time. This will give me the opportunity to work with the drawings I need to manufacture for the parts and initial back-bracket will probably need to be milled out of aluminum since it will contain critical positioning of holes and groves for the lug itself.
So sorry guy and girls if anyone was expecting this to happen swiftly. This is the best I can do and I assure you that I want a top notch product. If you want this product as much as I do, I am sure you would argue the same.
If one can get the best, then don't settle for less.
