I cut some steel rod slightly longer than the width of the tang and scales. Then I drilled the scales and tang to a slight interference fit. I put epoxy on the tang, put the scales on, then drove the pins thru leaving a little hanging out on either end. I clamped it together and let the epoxy cure.
Then I peened over the pins and ground them flush.
Fuel...that's beautiful, my man! :cool Excellent work...and yes, I think a "ball" on the end of the handle might facilitate the wrapping and knotwork (I'm running into that problem now with my version :angry)...but, it looks like you nailed it! :thumbsup
