I'm working on one of my first props project but I've hit a point where I'd like some thoughts and advice.
I need to bend a cast acrylic rod (1 1/2" in diameter) around a form without breaking it and hopefully maintaining the clarity of the plastic. I've heard that some people use heat tape, like around water pipes, but I can't imagine that would be hot enough. Any thoughts?
I also need to cut the rod and make the ends as clear as possible. I was playing with a sample piece that I have but the crosshatches of the sand paper always showed through. I tried using a heat gun but that just caused the acrylic to bubble and lose clarity. I'm really kind of stuck so anything helps!
Thank you!
Thank you!
