Assassin's Creed III - Ratonhnhaké:ton’s Hidden Blade
Kouri
On a whim, I ordered a print of the Connor Replica Toy Kit from Ammnra Creations. It's an SLS Nylon kit that creates a gravity-fed hidden blade. The instructions made assembly straightforward, and right away I had the blade flipping in and out.
The material has a porous surface and took paint really well.
After a while, though, the kit irked me with how inaccurate it was to the in-game design. I really wasn't invested into this prop enough to scratchbuild an entirely accurate Hidden Blade, but I figured I could at least modify the dagger handle to include the rear flip-out blade from the official artwork.
This involved cutting into the rear of the dagger handle to make room for the rear blade. The handle wasn't thick enough to carve a recessed area to house the blade, so I instead made the main blade thinner. Styrene was too light for the gravity-fed mechanism to overcome friction, so I opted for 0.063" Aluminum. The rear blade would then be held in with a screw to allow it to pivot.
Afterward, the kit was repainted, clear coated, and then weathered.
The wing details on the blades were accomplished with careful paint masking. The blades were painted up in gunmetal, masked, and then painted over in silver. This left the "engravings" slightly recessed. It was a neat effect, but, sadly, the clear coat smoothed everything out.
I didn't want too long a wall of redundant photos, so the rest of the image gallery is available on my site:
Assassin's Creed: Ratonhnhaké:ton's Hidden Blade - Kouri Kustoms
Excellent!
Rob
Sent from [location encrypted]...somewhere on the Tharkside of Barsoom ;)
Excellent I look forward to it :thumbsup
Well look no further, here's the video demo:
(Apologies for the quality, but I live alone, so pocket-cam-in-the-mirror is the best I can offer on short notice)
It's tied to my arm with some shoe laces. I haven't sewn together proper straps, because I'm hoping to have the time to learn some leather work and cook up an accurate bracer to mount it to.
Holy crap!!!
I'm a huge AC fan and this is wicked cool!
That is beautiful....
Thank you kindly, folks.
That's some awsome work there, looks like it all works really well, nice one :D:thumbsup
Awesome work, really like the addition you made to the blade.
How is the blade mounted anyway? It looks like it's locked in solid, and then you can still flick it out to rotate it. Is it mounted on a peg and a slightly raised area to keep it in place with friction?
Thanks! It's a bit tighter with the two blades in one handle, but the replacement metal main blade helps the whole mechanism overcome friction.
Fantastic job.... I need to pick up one of those kits and get to work
If you're ever looking for a replacement metal blade, I managed to cut a few extra off of the template I used on Connor's blade. They're not thin enough to fit the rear blade into the handle, but they pop right into the Connor and Osiris (It's Ammnra's "modern" take on the AC3 Pivot Blade) kits without any modification. I'd recommend replacing the thin paperclip pin with a slightly thicker steel screw though.
And now I'm realizing I probably should've inserted an image of the kit with the dagger separated. Ah well, here's a quick doodle:
The green circle represents the pin that holds the dagger to the arm mount. Think something like a wide nail head sticking out the bottom of the dagger handle. The inner diameter of the pin fits into the hole in the middle tier of the assembly, while the wider pin head keeps the dagger from popping off. The pin generally sits at the front end of the middle tier, but it does have some room to slide back.
If the dagger does slide back, as it would from the impact of a forward thrust, there's a guide rail (marked in yellow) that tabs into a groove in the rear of the handle. This physically prevents the dagger from rotating until the force is relieved, at which point the magnets (marked in red) pull the dagger handle forward again. When the dagger is in the forward position, the magnets keep the dagger blade oriented forward, but allow the user to rotate the blade at will.
I had puttied over the magnet slots, so they're not very noticeable in the Connor blade. However, if you look at the painted Osiris kit up top, you can see the magnet next to the blade lock since I painted right over it without putty.
