After seeing the build pics Volpin posted of his N7 armor build(I saw EvilFX built two awesome gender specific sets as well!), I got inspired to try and make the helmet to go along with the armor.
I did see Tommyfilth's build, and it looks like he has way more materials knowledge than I do, so I went with what is (I hope) a more straightforward method.
Last Saturday I started out with a basic posterboard framework for foaming:
Incidentally I think I'll use the same design if I ever need to make a stovepipe helmet for medieval armor!
I then added expanding foam:
And then came the shaving!
Lots, and lots of shaving. I found using a small hand held hobby saw works best, but anything with a good serrated edge works as well.
As of today, I have this:
My plan is to continue roughing out the general shape of the helmet in the foam, and once I feel its close, add clay/apoxie sculpt in order to better define the features/shape/lines of the helmet.
Eventually I would like to cast this in silicone rubber and make resin copies.
Any critiques, tips, suggestions from you prop veterans would be much appreciated!
While I wouldn't mind making a life size N7 bobblehead, I'd like to avoid it on my first prop attempt
