roundhammer
So I managed to wire up a set of working laser pointers for my helmet. The question I have for those of you that have done this, how do you align them, and once you do, how do you keep them that way?
I first tried using epoxy putty wedged in the middle of the lasers. I figured it would be thick enough that once I had them lined up, the putty would hold them in place and set...making the whole thing as hard as a rock.
But no, the putty was to soft and the lasers kept getting out of whack.
I then tried hotgluing them to one another. I first did two together...added some HG to one, and stuck a second one ot that and lined them up while lit. That worked, and I went on two the third. This seems to have done the trick, but I worry that if I wear this out when it's hot, that the temperature will cause the glue to go soft and the lasers will once again be all over the place.
I'm wondering if there was a simplier way of doing this that I completely didn't think about. What have you done that's worked?
