Airbrush Compressor Kits from eBay
76 Modeler views and no one? Maybe I need to post it elsewhere.
I'm just curious if this "type" of airbrush system with a cheap price tag could be used for model painting, props, etc. Not this exact item.....!
Anyone? Bueller? <chirp...chirp....crickets.... :confused>
I've bought quite a few budget airbrush kits over the years and these look average.
the problems you'll run into with theses are-
- spray width/quality, some of these aren't technically airbrushes but spray guns, don't expect too fine a detail or a confined spray. there may also be some "spatter" where odd flecks go everywhere.
- pressure, they have some adjustment but not a huge amount. coupled with a decent airbrush these compressors are fine but they usually don't have a tank so can be noisy.
- parts, most of these kits are non-standard, meaning valves, etc are not available for repairs easily.
Don't get me wrong these are fine for basecoating models and I would recommend a beginner to use a kit like these to get the hang of airbrushing, but you can get a decent quality airbrush and compressor for just a little more.
I got my own setup, a 2mm line brush, hoses and compressor and spares for £80 from everythingairbrush.co.uk.
shop around, ask in the JY, you never know whatcha might find.
Maybe its just me,but it looks kinda crappy.Something you'd get from Harbor Freight.I'm a firm believer in "you get what you pay for".
In terms of airflow you can get the same flow from an industrial sized compressor ($500) that you can from a weed sprayer ($39), I've done both. Air is air as long as it's clean.
I like a compressor with a tank because hearing the air is part of the feel of airbrushing. A noisy motor ruins that. This little guy will be running the whole time, and will be noisy unless you can isolate it somewhere. Plus, if the 'brush is having a hard time or spitting, your eyes will actually be the last sense to catch onto that fact and you certainly don't want the results of a failure on your subject. Thus, your quietest options are either one with a tank or a weed sprayer. :love
If portability is your concern, then little units like this and weed sprayers are your only options, but if I were you, I'd be looking for new vice refurbished and I'd probably seek one out locally in case I had to take it back.
I don't run an airbrush too often, but I bought a $99 sears jobbie, and added the moisture trap. The plus with this machine is that you'll find yourself using it for other tasks - tire inflation, blowing grit out of stuff, shooing cats, etc.
Get one with a tank and a cheapie dual action airbrush from Harbor Freight. A running compressor will drive you nuts in 5 minutes.
