I have found passable replicas of the belt buckle Vivienne Westwood ring on etsy and have one ordered. They presently have the original replica and one that is an adjustable band.
I am feeling this quote more and more as I find the sources behind his purchases. I am going to put together a total price package estimate when complete. With just the watch at 20000 plus and each ring (most are Vivienne Westwood) at 3 to 500 per, the number for just one outfit will be very very high.As a huge Adam Ant fan, I will be following your builds with great interest! I'm not sure I will be able to contribute much beyond encouragement as my knowledge of vintage clothing is nil... but I like that you plan to "...spend your cash; on looking flash; and grabbing our attention."
Agreed, after reading your post, I can see it does seem to go up into the other half from the lock clasp location. Where the clasp release is, seems a great place to accidentally rub up against something and dislodge the entire bracelet.First, fantastic work on your diligent research! I appreciate getting to follow along. The Vivienne Westwood connection makes a lot of sense given Adam's fashion history (and hers). Second, good to know that he is doing well, or at least his accessory budget is flush ;-)
My first thought on seeing the twisted silver wire on the bracelet was perhaps it is a fancy way to reinforce the locking mechanism - me thinks that is a pricey accessory one would not want to slip off while dancing on stage. Just a guess though.
Oh, I think you have caught me boxing Adam Ant when he doesn't stay in the box. He does most definitely make his own way and this was definitely one of them.Where would you put the Apollo 9 look in the list? Street Punk? Biker? Both?
That's not an extra wire it's a clasp lock that straddles the ball on the side to keep the bracelet together if the bracelet catch fails. Also why do I hear "Stand and deliver" while writing this?Using the known size of 21.21mm as the standard stamped US Indian head nickel (ring on right hand) and using the nickel itself in comparison to the bracelet, I estimate the silver cuban men's bracelet to be 20mm wide links.
He has an added silver wire twist on the first link and I am unsure of its origin or significance. The bracelet I have found as my cosplay base is:
I will likely brush it with a wire brush or buff it on a polishing wheel with grit to produce the true poured silver look of the original.
Great ultra closeups of these items. Had no idea there were charms on the chain.I found these - related to the Kings outfit - and thought you might find them of interest. Apparently it was on public display at one point?
And....
There are several of the old serpentine style keychain fob cables. That at least should be thriftable. The diamond pattern knurling is greatly unexpected for a chain of this link type. From a distance it is just dog lead chain but up close they are all custom links.Looks like the chain has a diamond cut to it and joined by a chili pepper dangling on a Carabiner ring
The dolphin and whistle look like attached to a old style car key ring
The skull and bones on the chain is likely from an SS cap from WWII...Great ultra closeups of these items. Had no idea there were charms on the chain.
Love it.I figure I'd drop this here in the only thread that would appreciate it. To give greenmachines the continued inspiration.
The feathers on the right upper shoulder should be easy to replicate as well
