NOTE: there seems to be an electronic issue with this item, the pistol lights and shakes as long as the p1 (where the battery is) is installed. This just stated happening so I don't know what's causing it. Still displays great though!
This piece is still available. Top quality work on this modified and repainted Wand TOS phaser.
The machined aluminum emitter nozzle from a Master Replicas phaser replaces the plated one that came with it originally.
Grip included is a casting from the Master Replicas grip, which is more accurate than the thin one supplied by Wand. The bolt is metal so the magnetic Wand display stand still works.
The p1 meter label is changed out for a prop-accurate one, and the entire piece was repainted in TOS colors.
Polishing to the "dilithium crystal chamber" side knob and the heatsink fins on the tail has thinned the plating a bit but it still displays well.
