So I've been doing a fair amount of research, calling companies, etc. regarding what material to use when making my mask. The material choice will be a bit tricky as it is to be an animatronic mask.
So my choices are:
Latex cast in Ultra Cal 30 - simple and inexpensive but the flexibility could be a serious problem, even with softening additives
Foam latex- good flexibility but quite a bit more of a pain to work with as it requires an oven and from the companies I've spoken to the durability is questionable
Silicone- excellent flexibility and outstanding realism but slightly more complex molding procedure and greater expense- it's also heavier than foam latex. I am very familiar with working with silicones however and fully understand them. Some silicones require the use of a vacuum chamber and some don't- I have a vacuum chamber at work if needed but the material I'm looking at using right now doesn't rquire it.
Another idea I had is to make a standard Ultra Cal 30 mold and do a thin latex coating. Then I would lay in some thin upholstery sheet, give it a coat of latex and vacuum bag it under slight vacuum. Anyone ever tried something like this?
Any help?
So my choices are:
Any help?
