10" Jabba the Hutt Supersculpey build
NemesisCustoms
Hi folks
Here is my finished Jabba the Hutt 10" handsculpted figure
Here are some wip pictures
ImageUploadedByTapatalk1386931808.741102.jpgImageUploadedByTapatalk1386931819.090780.jpgImageUploadedByTapatalk1386931828.057436.jpgImageUploadedByTapatalk1386931839.507367.jpgImageUploadedByTapatalk1386931855.474002.jpgImageUploadedByTapatalk1386931863.774419.jpgImageUploadedByTapatalk1386931874.873884.jpg
Thanks for your feedback!
Baking that stuff with the foam base will be a little bit of gambling /-:
I will try to increase the temperature in little steps
Instead of baking him in an oven cook him in a big pot of boiling water it shouldn't damage the foam core.should also reduce cracking.
I just finished the sculpting... only a few minor cracks that i have filled with some epoxy (-:
When the primer has cured i will hit him with the airbrush
ImageUploadedByTapatalk1387120077.221610.jpgImageUploadedByTapatalk1387120094.571927.jpg
Nice work! I built a Sculpy Ziro the Hutt with a foam core. The core melted when I baked him (I also had some cracking). Love the textures you accomplished.
No matter what you used as your core; that is a great sculpt. It looks like you used the Illusive Maquette as your inspiration. the pose looks exactly like the one I have; but in a better size :D Can't wait to see more of the fantastic work you are doing.
Looks really good already, so more detail will make it perfect. You should make a little Salacious Crumb next to Jabba.
Hey very nice work. I use Supersculpey for doing prop gun builds. Nice to see it used for the right thing. Well you doing a Jabba the Hutt, I thought I would show you a really big leather patch I made for a custom order. Most people don't know that Jabba has a tattoo or brand on his arm.
