Bandit-Jedi
Awesome!
looks fantastic, I'm definitely in when it comes to a run.
correct me if i'm wrong though (because i don't know the specifics of this prop so i probably am), but aren't both ends supposed to light up? or does only 1 end light up in the film?
The test looks very good and I like your magnet closure for the battery compartment so there are no screws showing.
I would recommend using clear resin rather than transparent blue. Then people can change the color with different LEDs or glass paint. Or were you going to make multiple colors of tinted clear resin?
looks good, a little "rough around the edges" though, is this the final version or is there clean up to be done?
Thanks for doing these kits! I can't wait to get it and get it all painted.
I did a test with wadding filling the groove from which the light must pass, squeezing it with something small pointed, and the result was decent, the leaves of cotton lint though, so you need to try something else, but the system is good.
