XRobots
Should I attach the faceplate, coat the whole thing and then cut it loose? Is it perhaps that my foam is too flimsy? I have been making it out of a camping mat, 6mm.
You could try gluing cardboard formers inside the helmet so it holds it's shape while you coat it, and then take them out afterwards - basically flat bits of cardboard at right angles to the sides glued across the inside of the helmet etc.
