Twananas
I started a few months ago with finding materials to make the most perfect costume in my vision. It's taking time and money, need to save some again before I can go on. However I got quite far with resourcing! It's my first "big" project.
I finally made a few decisions on my fabric choices for Elsa! I am going for a more blue pallet as in all merchandise and art work it is closer to blue than turquoise. And the art team describes her colours as blue and it is all ice.
Still waiting for a few fabric samples, however if they are not right, I am almost there!
The main dress will be made out of 3 layers of fabric. A silk georgette top layer with an ombre dye, a polyester hologram layer under that for sparkle effect and a trophy blue/regal silk dupion for the lining.
The bodice will have canvas supporting on the inside and a net layer on the outside with hand cut sequins and rhinestones glued on.
The undershirt will be made with silk georgette or chiffon. However georgette has a more organic feel and is less shiny. This depending on the samples to come as there was a nice looking mesh cotton which is close to what she wears in the movie, though it needs to have the right feel. Also the sleeves will be ombre dyed.
For now I will use small crystal beads for the snow pattern.
Finally the cape will be made with a net mesh. For the snowflakes I will seal crystal organza with a layer of glue on the back before cutting to prevent from fraying. I will also add glitter for an extra sparkle. Then I will glue them onto the cape and finish it with crystal beads mainly in the top part of the cape where you see more snow. I want to use magnetic fasteners to attach the cape to the dress, as this seems to be easier to attach and remove it if you happen to be on your own. Some testing would need to happen first to see if it holds the weight of the cape.
In the meantime I will continue cutting sequins with the smaller puncher!
Here are a few pictures. More pictures and WIP updates can be found here: Twan Lentjes
The main fabric for the dress is a little too green and this is a polyester. These sequins are just hand cut by scissors, a test before I got the puncher.
