thatdecade
My progress has stalled for now. Parts are laid out on my bench, design is near finished. All that is left is integrating all the pieces and building a prototype. Then I can start selling kits.
Hey guys! Is anyone still making any of these for people who want to buy one? Just thought i'd check coz it's a pretty old ongoing thread now!
Source | Category | Part Name | Part Number / Link | Qty | Description | Comments | |
DW | Core | Circuit Board | Contact: thatdecade@gmail.com - or - http://www.abra-electronics.com/products/Syntac-PC-Board%2d85mmx95mm.html | 1 | Syntax PCB | ||
DW | Core | Graphic on sticker photo paper | 1 | Meter Color Graphic | |||
Misc | Core | P-Clip | http://www.fiberopticproducts.com/store/product_info.php?products_id=772 | 2 | Antenna Clip | ||
Misc | Core | Meter | http://www.menards.com/main/electri...eter-5-function-12-range/p-1460423-c-6452.htm | 1 | Meter parts | Dismantle for the analog meter needle mechanism | |
Fastenal | Core | Screw Posts | 3/16" Outer Diameter x 5/8" Length x #4-40 Thread Hex Aluminum Female / Female Standoff | Fastenal | 4 | Hex Female / Female Standoff - 5/8" Length x #4-40 | ||
Fastenal | Core | Screws | #4-40 x 3/8" Phillips Drive Pan Head Zinc Finish Steel Machine Screw | Fastenal | 10 | Phillips Pan Head Machine Screw - #4-40 x 3/8" | ||
Fastenal | Core | Washers | #4 x 0.312" OD Low Carbon Zinc Finish Steel SAE General Purpose Flat Washer | Fastenal | 12 | Flat Washer - #4 | ||
Fastenal | Core | Nuts | #4-40 Zinc Finish Low Carbon Steel Hex Machine Screw Nut | Fastenal | 2 | Screw Nut - #4-40 | ||
RadioShack | Core | Hookup Wire | RadioShack.com Official Site - America's Technology Store | N/A | Wire | ||
RadioShack | Core | Antenna | http://www.radioshack.com/product/index.jsp?productId=2062262 | 1 | Antenna | If too long, cut shorter with bolt cutters. | |
RadioShack | Core | Magnet Wire | http://www.radioshack.com/product/index.jsp?productId=2036277 | N/A | Multi-gauge Wrapping Wire | Use to create the two coils and wire clips | |
Digikey | Core | Ribbon Wire | MC09M-5-ND | N/A | Rainbow Ribbon | Split apart and route around board | |
Digikey | Core | Toggle Switch | CKN1047 | 1 | Toggle Switch | ||
Digikey | Core | Thumbwheel | 3352T-103LF | 1 | Do Not Buy | Salvage from the analog meter | |
Digikey | Core | Trim Pot | 3362U-103LF | 2 | Potentiometer | ||
Digikey | Arduino | Battery Clip | SBH331AS | 1 | AAx3 Batter Clip with Switch | ||
Digikey | Arduino | C5,C6 | 709-1172-1 | 2 | Chip Capacitor | 805 Version | |
Digikey | Arduino | Crystal | XC1776CT | 1 | Chip Crystal | ||
Digikey | Arduino | Resistor | RPC0805JT10K0CT | 1 | Chip Resistor | 805 Version | |
Digikey | Arduino | C10 | 1276-2890-1 | 1 | Chip Capacitor | 805 Version | |
Digikey | Arduino | Chip | ATMEGA328P-AU | 1 | Arduino Chip | P version | |
Digikey | Audio | Speaker | 433-1104 | 1 | Speaker | ||
Ebay | Audio | Amp | PAM8403 Breakout | 1 | Amplifier Circuit | This is a generic small speaker amplifier that is common and cheap on ebay |
