FIREWIRE
Member
Hey guys.
im looking to make a slush casting in which i sluish around 3mm acrylic parts i have. these will be used as mounting points for electronics i have ready to fit.
i have done several tests but the resin doesn't seem to want to adhere to the acrylic very well.
i have sanded the surface with rough paper and scored heavily. i also plan to drill lots oif anchor holes half way through for more surface area to grip. the acrylic will have one side where the resin will touch and the other side will be left untouched to mount my parts.
I was also planing to run a thin layer of bondo (.5mm) and mottle.
the resin sticks rock solid to glass which is weird as it is just as gloss a surface
any suggestions would be much appreciated.
Thanks
Thanks
