Belated Update time!
First, thanks for the kind words everyone! I'm happy that these builds have been so well received
I've neglected this thread for awhile and to anyone following it, I'm sorry! Things started getting down to the wire for the build and I wasn't able to keep up with regular updates. Now that things have settled down, I'm happy to report that the suit was completed and Ohio Wizard World was a success! I've finally got everything uploaded, so hold on to yer butts while I link all the things
Maximum Carnage!
Looks like I last left off at the base coat stage. There might some overlap in these descriptions, but here goes:
My cell phone camera doesn't do it justice, but you should be able to see a slight marbling or camo effect with the red here. The base layer is Krylon Cherry red, and then accented with Krylon Banner red.
The helmet I got was already primed by Sean, which saved me a lot of time. I taped of the visor area so there wouldn't be paint on the inside. I did this because the paint would smell, and needed to put this thing on my head a week. Can't take that chance.
One the base layers of red were done, I wet sanded up to 3000 grit to keep that 'wet' look. I then taped off the details I wanted to accent with a metallic steel spray paint.
Here is a forearm during the detail phase- doesn't look like much until the plastic and tape is removed.
More taping, more spraying, more details. The steel paint is by duplicolor, but I forget the exact color.
ODST DeadPool? ODSDP? wat?
Here are the pieces without the masking tape. My first thought when I removed it all was "I could just stop here, and make it a Dead Pool suit" but that quickly passed. I need Carnage!
Here is a close up of the details. Patience when masking really makes a difference!
The shoulder pads\straps
This part was my least favorite on the build for Venom, and that didn't change for Carnage. The straps themselves are made out of EVA foam mats, cut to size.
Where it gets less fun is that I decided to wrap them in vinyl, to give them a more leathery look. That's not too bad in itself, but then I had to hand sew a nylon strap down the length of each side. Those straps are what connects the back to the chest.
These parts themselves took me several hours to complete, but I could only work on them in small bursts.
The way they look at the end is what makes it worth it.
A lot of the ODST parts overlap (like a real suit of armor would) in places, and that can make the pieces bonk and clang together. While I may sound like a squeaky tin-man when I walk, the real problem is that the parts rubbing on each other dulls and then scratches the paint finish.
To reduce this, I added more EVA padding and vinyl where the parts would rub. This protects the finish and also makes it quieter when I walk. You can see an example of that padding at the bottom of this hip piece, before I glued the vinyl on.
These are just basic full fingered paintball gloves that I painted red to match the suit- these are very common for Halo cosplays because they are cheap and look fairly close to the game. Taping these off was a pain, but the end result was worth it. The paint adheres well to the plastic on the glove, but once clear coated it gets tacky for some reason and I don't know why. It must be leaking some chemical the paint ,interfering with them.
They get less sticky over time, but it very inconvenient.
Belt buckle and crotch guard
The majority of the ODST suit is supported by wearing a thick web or pistol belt. Pieces like the hips, butt, crotch and thighs all hang from this belt- they way they do that is by simple parachute buckles and nylon strapping.
It's a little loose to make it easy to snap on and off for donning\doffing the suit.
Torso
Here you can see where the shoulder straps are riveted to the back plate. The back plate itself is made up of 3 pieces, an upper and lower back, and a front collar in the front that is detachable via velcro tabs.
(You're seeing the inside of the back piece here, where no paint is applied.)
- continued in next post -
More Carnage!
Here are the rest of my build pics
The side connections
The back plate has two.... prongs that come out and hug you when you wear it. You have to add more straps here to keep the back secured to your body. I built this kit (and the venom kit for that matter) to be wearable by my friends, so the strapping needs to be adjustable.
One cool thing I found was that if I did the strapping in a certain way, I only had to sew one end and friction would take care of the other end when wearing it, so I could adjust the strap to fit someone with a bigger waist, or remove it altogether if I wanted.
Here is 1 of 2 straps setup. The buckle you see here is where the chest piece would meet the sides. The other half of the buckle is riveted to the chest.
As I started getting all the pieces wearable, it became time to acutally WEAR them so my fiance could being painting the black details.
I'm pretty good at symmetry and a more machined look, and one thing I really struggle with is free-flowing and more organic forms. You'd think painting a bunch of black squiggly lines would be simple, well, if your a perfectionist, it's hell! It's akin to trying to draw something on paper, making two lines, and then crumpling up the paper and trying again haha.
SO, I enlisted my Fiance to assist since she does the free-flow stuff way better than me. She did an AWESOME job! First time we've ever worked on a project together, we might have to do it again
Boot caps, no gloss, with gloss
Here are the toe caps that slip over the boots.
The one on the left is without a clear coat, the one of the right is with a clear coat.
Normally in Halo armor, people tend to use the matte clear coat as glossy can make it look too much like plastic or a giant toy. In my case, I went with gloss because it makes it look WET, like I envision the symbiotes to look.
To make it look extra wet, make sure you prep your pieces with as high a sand paper\sponge as you can! It makes a difference!
Crazy eyes
On Venom, I did so many damn eye prototypes before I decided on one. With Carnage, I somehow hit what I wanted on the first try. Go figure.
What I did is draw out one eye to size, then cut the paper template out and use it to cut out a craft foam template that can be flexed over the physical helmet, to trace out the eye.
For Carnage's eyes, I went a little bigger, a little rounder than Venom's eyes.
Here's a pic of the Stencil I made to paint the name on the chest plate.
It takes a few tries to get the size and spacing right, and then I take the card stock and lay a piece of painters tape over it, then cut the letters out with an x-acto knife.
Patience here counts. The details are very small.
Once cut out, I then tape it over the chest where I want it, and hit it with spray paint.
By this point the base red coat had dried. I then taped off the details I wanted to preserve red (that would be where you see the blue tape) and then I taped off the crown where I wanted the eyes.
Once taped, I traced out the eyes with the template I made, and then very carefully cut out the eye with my x-acto blade. I had to press hard enough to cut the tape, but not cut into the paint if I could help it.
Everything else was masked off, and then I lightly sanded the negative space of the eyes, wiped it clean with rubbing alcohol (to promote better adhesion) and then sprayed they white on.
With the paint dry, and the tape removed, they eyes came out fantastic. I think I nailed that creepy look I was aiming for.
I also had the teeth finalized by this point. To make them, I cut them out of craft foam in various sizes and then glued them on the visor how I wanted them.
They don't really interfere with visibility at all, and look different enough from my Venom suit that it doesn't come off as a copy.
The ODST visor also makes it look like he's smiling, which adds to the creep-o factor
Here is the chest with the black details and name painted on.
Here are the arms with all details and clear coat.
I really like the back details here. My Fiance totally nailed how I wanted the lower back to look- By blacking out the recessed areas, it makes it look like some of the skeleton is showing.
Pretty neat!
Here is a closer look at Carnage's maw.
The silver visor is a nice contrast to the black teeth I did, and the pant job matches them perfectly.
Here is the helmet with the black details painted on and clear coated.
I don't really have words here. It came out exactly as I wanted.
Beautiful.
More helmet. Again, I don't have words.
Why can't this be in the game? C'mon 343.....
Here are the two helmets next to each other. I'm still planning to get a friend to wear one of the suits so I can take some real pictures with them.
Carnage and Venom.
From the front.
I love them.
I want more.
I have a problem.
What color do you bleed?
This is one of my favorite details- in Halo, the ODSTs where their blood type on one of their shoulders. I thought it would be a nice touch on this cross-over if I put something special for Venom and Carnage's blood types.
Venom is V+ (venom positive)
Carnage is C! (carnage....EXCLAMATION AHHHH)
Here are all the parts laid out on my work tables, read to be put on.
Go time.
Here's me putting the suit on for the first time. I learned a lot from my Venom build, so I made some tweaks to the Carnage suit and it fits me way better.
-continued in one more post-
Moar Carnage!
Complete!
After a lot of sanding, painting, riveting, padding and sewing, it was all ready. It came out perfectly!
Slice n Dice!
When I decided to work on the Carnage build, I decided early on that I wanted his weapon to be a Covenant Energy sword.
Luckily for me, Sean had one waiting for me. With the help of one of our friends (nameless, to protect privacy) he wired up some custom electronics for me that make the sword pulse like it does in the game, AND it changes colors.
On command.
When I want.
Because reasons.
Anyway, in the comics, Carnage is able to manipulate his body to make weapons out of his appendages, like axes or hammers.
I thought a red energy sword would be a nice analogue to that, the Halo style if you will.
Convention pictures
Here are some of my favorite pics from the convention. Lots of people knew exactly what I was right away, which made me really happy! I didn't see any other Halo folk there though.....where you at, 405th???
The artist of this booth was kind enough to let me get a picture in front of his Carnage painting
These kids, these kids were so happy to see me and I was happy to take as many pictures as they wanted.
Not pictured: Dad shoving kids out of way to get HIS picture haha
Am I official now?
When does the money start showing up?
Saw these at a booth and had to buy them I saw a set a dragon*con and didn't get them, but I did this time!
A t-shirt booth actually had some pretty good stuff of characters I like, so I jumped on these. Also got some decals of other things I like for my armor cases.
LadyPool wanted a picture. Who am I to say no?
(Side note: There were like 50 DeadPools at this convention. All trying to out pool each other. I just....can't....why....bleh)
The Fett man!
Surprisingly I only say ONE at this convention.
That's all for now. While there I met a professional photographer and he snapped several photos of me and I'll be sure to share them here when he posts them. I had a great time with this build and can't wait to do a shoot with Both Venom AND Carnage!
Special thanks to Sean Bradley for the awesome kit and Sword commission, a special person for the sword electronics (not named for privacy) and my fiance for co-painting it with me.
THANK YOU, for reading and the kind words
