Sorry for the delay, didn't have time until now to work on this:
For my harness, I bought 2 -
95lb Round Pull magnets (Harbour Freight).
My plan was to have the magnets attract each other, but upon initial tests, they slid off each other when turned vertically.
Solution? Add a pin! I used a
#10-32 1" screw w/ washer as shown:
I then got old
earbud wires as they are flexible enough as well as strong,
AND I had a few dead ones lying around.
I used this to secure the magnet to the harness, as the harness
is metallic, however not consisting of anything that the magnet can stick to.
I strung the magnet through the loops in the "leather" straps as shown:
Then pulled it tight while slipping the screw through the existing hole in harness
(Which is why I used #10 screw as it was the exact size of hole:
What it looks like from reverse angle:
Then the other magnet simply sticks to the shield, as I have an aluminum one:
Magnets have enough pull to attract one another:
And lifting the shield with magnets and harness:
Takes some practice to get the magnets lined up, but the screw sticks out enough to connect with the other magnet and prevent it from sliding off.
Hard hits to it will still allow it to fall off, so I would not say it is Convention-ready.
The magnet on the shield is held purely by magnetic attraction, however it is more than enough.
Be sure to have something like a string or screw through middle of magnet when trying it out, as sticking it on the shield or other large flat surface makes it difficult to pry off.
Sorry again for the late and long post, but hopefully it helps some of you!
EDIT: I am currently trying to balance out the weight-- it makes the harness sag down, and cause misalignment.
Temporary solution is to pull straps until desired location of shield/harness and use safety pins to keep it there; in the end I think I will sew it in place rather than have the straps free moving along back piece.
