Hello!
Any love for the ESB severed hand stunt? I haven't seen any thread specifically about it, and since it is such an enigmatic prop, I thought I start one.
Why now? Because I was approached by Diego86 with the question if I would consider doing some replica parts for this and we had a nice discussion going so far. This does NOT mean that every question I get will result in a new WannaWanga project, but it happens!
Here are some known pictures:
This first image is from a book called Objets du Mythe. The French book from a French collection. The second image I have no clue where it's from.
These images also seem to be in a French book, and I would really like to know which book (it's not in Objets du Mythe), because I couldn't find a better version of the total image on the left. A good scan would be a great reference.
And some screen shots:
And this one from behind the scenes, with Mark's hand holding Luke's hand:
While looking at these images I had a few thoughts:
And yes, I am considering doing a small run of the parts: the connector box, the cone knobs (thanks to Diego for measuring his vintage cone knob) and red button with collar.
I'm very excited as you can probably tell!
Cheers,
Roy
- I'm really intrigued by the mechanical solution of the grip handle and my first thought that it looks like a pop rivet gun, holding a pop rivet in the hand part. I have searched for vintage rivet guns but couldn't find a similar looking one. Anybody knows what it might be?
- There are two Michell cone knobs in the Graflex port holes, but what's that part in the glass eye hole in the BTC pic? It doesn't look like a glass eye. But it DOES look a bit like the valve part from the DV6 stunt! But it obviously fell out and left glue residue in the socket. Intriguing!
- Diego86 suggested that the red button might be similar to a Kobold red button. But a Kobold red button has a dome. But looking at this red button it DOES like as if it was sanded down. I don't know why on earth a prop maker would do that, but it could be. I haven't investigated if the size matches yet. The collar might be a shaft collar, but I haven't seen any set screw hole on it. And we do have a view on both sides but no hole visible. So it was probably something else.
- I wonder about the area between the Kobold flash and the Graflex top:
All the Kobolds (and Linhof) flashes I have and I have seen, have a knurl on top and that area is thinner. So what do we see here? Is it a custom connecting bracket that is used? - Then the faux 'clamp box' connector part. I actually don't have any thoughts on that. It's still a mystery where it came from. What does strike me as odd, it that it attached on one side with a screw (and tiny internal bracket) but not on the other side. Strangely asymmetrical. How then is it attached close to the thumb? Maybe just glued.
Cheers,
Roy
