rogerrabt
Ohh, ok. I'm pretty sure the Denix just has solid metal where that's supposed to be. I hope it doesn't block the space I need to hold a magazine spring and follower. As you probably read I'm trying to get mine to chamber 9mm dummies
Yes, it's solid metal on the Denix. On the video that veektohr posted earlier, you can see it clearly. I pointed it out with a red arrow. The green arrow indicates where the trigger/plunger spring is held with 2 tabs causing it to push down on both the trigger and plunger. Best of luck getting it to feed dummy rounds; it will be quite an achievement!
