Help Find! Original Treasure Planet Map Design
I finished printing and painting the pistol
I would legit pay you for this 3d print design my dude
I don't remember what color this specific pistol fires. Is it kinda blue-white like these ?
I really wanted to put LEDs and a soundboard in the pistol but I would have to remake the model which normally wouldn't be a problem but fusion 360 dose some really stupid things that make it really annoying when you have to start from scratch.
Also made a model of the RLS Legacy (work in progress) first two pictures are the most recent. I'm still trying to determine weather I want the sails or not, I can make them but they'll never look as good as they do in the film.
I was thinking a sound board and maybe a visible laser or similar that in the near-dark and a fog machine, it could actually fire a BEAM of light out of it. :cool:
Also made a model of the RLS Legacy (work in progress) first two pictures are the most recent. I'm still trying to determine weather I want the sails or not, I can make them but they'll never look as good as they do in the film.View attachment 1439328View attachment 1439329View attachment 1439331View attachment 1439332
Sorry about the lighting on the first two, this one is a little better
josh1917 , holy hell... you're work is amazingView attachment 1439982
Got any work in progress shots of your map?
I might, I tend to forget to do that, this is the only progress picture I took.
Posting a bit of an update I've been working on the mechanical pen parts for the majority of the time but I think I've finally got a system that will work reliably for this! I also was able to reduce part count by including a section of the mech in the core of the map itself. I then spent probably a good week or two getting a bump map figured out for the surface texture, I think I still need a few tweaks for the finer detail but overall I'm really happy with how it's turning out! I am getting a more ABS-Like Resin on monday so that should help prevent scratching ect. and I think for a finish I'll likely be using a metallic powder and rubbing over the surface and then doing a matte clear coat. I think I'd like to do a run of these but with over 100 parts and finishing time required I'm still unsure of the cost. I also would like to test this on an FDM machine but don't it would likely need to be done on a 0.1 mm extrusion to minimize the friction on the mechanics. Oh I did also get spring and screw hardware in and that'd been working great! I even made room for springs being the screws so that there is a little bit of play like there is on a rubix cube! Hope to finish a completed version by end of may but we'll see! :)
View attachment 1452087View attachment 1452090View attachment 1452089View attachment 1452088View attachment 1452085View attachment 1452091
Cant wait to see it finished.
