I got my second helmet this week. Finally...
the second one is a live action episode 2 helmet from Bounty Helmets in the UK. I ordered this one in April.
Glad it finally got here. not sure why the seller sent it this way with the face plate already cut out, which I would rather do myself unless there was something wrong that they didn't want to show.. its roughly cut and drilled, but they also scuffed the surface and scratched it pretty good in a couple spots.
I also saw some other issues needing to be fixed before paint..mould separation lines that are fairly deep, and some very thinly distributed areas and some completely disconnected spots that I can put something thru especially in the areas of the jowels.
It definitely has a different shape than the Kenobi, and overall is a nice bucket. the resin seems to be fairly thick overall, very smooth inside, and the neck area is much thicker than the Sanotized Creations helmet.
The Kenobi helmet is now in paint stages. I have a coat of nickel steel on it over the primer. This Bounty Helmets bucket is just out of the box in its green skin arrival.
I'll be working on prepping the Bounty helmet so i can get these both to the same spots and continue to share some comparisons and paint them at the same time.. although they will be different when finished.
Enjoy photos.. if you have questions please let me know
I may end up starting a thread for the Bounty helmet to keep the helmets with their own progress.. just wanted to compare these two while i had some time.
