Page 1 of 19 12345611 ... LastLast
  1. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 8, 2011 - Tutorial: How to build a stormtrooper helmet for less than 10 GBP FINISHED see Pg9 #1
    Well, as my printer is Kacked, and I cant afford a new one right now, I have had to postpone the Pepakura build of a Stormtrooper Helmet that Fierfek so generously sent me. So.....What to do???
    I decided to set myself the challenge of building my 'Bucket' anyway, but from general household crap, such as toilet roll tubes, cereal boxes, newspapers, and on a budget of up to £10 and not a penny more. I have also set myself one week to achieve the finished article, from start to finish and it must be as close to screen accurate as possible but wthin reason considering the budget and time constraints.
    Finally, I should point out that this will not include the fiberglass casting and molding - just the the construction of a finished helmet which could be used as a display piece, or from which a mold could be taken.
    If anyone thinks this might be of interest, or completely insane!!! lol! then please let me know and I will start posting the build up here.
    Thanks everyone, in advance
    Last edited by Atlanthia; Aug 1, 2011 at 7:09 AM. Reason: The title was unintentionally misleading, so I have clarified it.
  2. dkaniel's Avatar
    Join Date
    Nov 2009
    Location
    Manteca, CA
    Message Count
    152
    Jul 8, 2011 - Re: Stormtrooper Helmet for under £10?? #2
    I am definetly interested in what your results would be, so please post your progress with photos!
  3. Formerly SamJ Psammead's Avatar
    Join Date
    Jan 2010
    Location
    Nottingham, UK
    Message Count
    198
    Jul 8, 2011 - Re: Stormtrooper Helmet for under £10?? #3
    I'm seriously interested to see how good (or otherwise) this will look. I just thought you could cover it in filler to smooth it out, then realised that that amount of filler costs £9. Good luck!
  4. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 8, 2011 - Re: Stormtrooper Helmet for under £10?? #4
    Ok! Here's the list of ingredients that I will be using:
    Three Toilet roll tubes
    One Newspaper
    Four Cereal Packets
    One roll of Sellotape
    One tube of Super glue / Crazy glue
    One tube of PVA glue (to be diluted 50/50 with water)
    5 sheets of white A4 paper
    One extemely understanding wife!
    So far, this list contains items that I have around the house already. My budget is £10, so I will be spending £6 of it on body filler/Bondo to coat out the finished product. That leaves me £4 for emergencies! lol!
    And my time starts..........NOW!!!
    First three images are the building of the dome. This involves 1 cereal box, lots of cutting, and loads of sellotape.
    Next : 3 layers of papier mache, (I have mixed the PVA glue 50/50 with water, this will go off like rock).
  5. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 8, 2011 - Re: Stormtrooper Helmet for under £10?? #5
    Setting the dome aside to harden up/dry, I've started construction of the lower structure. As with the dome, I have verified the outline/shape by tracing around an original ANH helmet side and front picture, which I enlarged onscreen and saved to my pictures. The size I have used is 12" x 12" x 12". This is approximate, as accurate dimensions don't seem to exist, or are a closely guarded secret.
    Dome placed upon the lower structure to verify that they fit together.
    Here, I have started to fit the rear panels to the lower structure. I have also started to cut up and attach the toilet roll tubes to form the lower, front facial structure.
    Here, I have tentatively cut and placed the eyes; these will require further adjustments as the build progresses, as they are fundamental to the look and overall appearance of the finished project.
    As you can see, I have now inserted all three tubes, and the base for the vocoder. This enables the whole structure to become much more rigid and allows me to take points of reference regarding dimensions, etc.
    Here, the front side panels are installed, which continues the contours from the rear of the helmet. This also will provide the surface on which the lower tubing will be mounted.
    I have joined the dome to the lower structure with papier mache and have also started to form the front features; difficult to make out due to the multi-coloured paper. I have also started to attach the formers for the bell housing, which encircles the lower part of the helmet.
    This front view, although blurry, shows that the front is now taking shape. As you can see, I have cut the frown and the whole build is starting to take shape.
    Bell housing has been coated in papier mache.
    Rear view after coating bell housing in papier mache.
    I have decided at this stage to coat the whole helmet in white paper; the reasons for this are three-fold: firstly, this affords much better definition when taking photos, and secondly, it will allow me to avoid purchasing paint, and thirdly, will show up any imperfections prior to body filler application.
    Build time so far is 2 days, so that leaves me 5 days to complete this project. I hope you have enjoyed this first installment and I welcome any comments or encouragement you may have. To all Star Wars officionados, I will reiterate that this is a budget project in an EXTREMELY short time frame!!! What I mean by this, is that if the eyes or the dome, or whatever, are not exact, please bear that in mind.
    Next installment coming soon......
  6. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 8, 2011 - Re: Stormtrooper Helmet for under £10?? #6
    Psammead said: View Post
    LOL! That depends where you get your filler!
    I bought two tubs at £2.99 each as they were end of line stock.....right place at the right time I guess!
  7. Join Date
    Jul 2011
    Location
    Springfield, OH
    Message Count
    64
    Jul 8, 2011 - Re: Stormtrooper Helmet for under £10?? #7
    Wow, that's pretty impressive for using what amounts to some trash, glue and tape. I definately want to see how the turns out.
  8. DanielS's Avatar
    Join Date
    Jan 2011
    Location
    Stockholm, Sweden
    Message Count
    410
    Jul 9, 2011 - Re: Stormtrooper Helmet for under £10?? #8
    I agree with leafman.. It's amazing considering the material used :P
    great job! can't wait to see it finished!
  9. NAZGÛL's Avatar
    Join Date
    Jun 2009
    Location
    Sweden
    Message Count
    1,682
    Jul 9, 2011 - Re: Stormtrooper Helmet for under £10?? #9
    This is totally awesome! Only using toilet paper rolls and newspaper... I love it!
  10. Formerly ManfromNaboo DaddyfromNaboo's Avatar
    Join Date
    Mar 2004
    Location
    Germany
    Message Count
    9,583
    Jul 9, 2011 - Re: Stormtrooper Helmet for under £10?? #10
    Plain awesome. Just plain awesome. I´d say change the thread title to "Tutorial: How to build a stormtrooper helmet for less than 10 GBP" for future reference
  11. Join Date
    Dec 2007
    Location
    London, England
    Message Count
    344
    Jul 9, 2011 - Re: Stormtrooper Helmet for under £10?? #11
    Feckin hell,that's good work,i have enough trouble ,with Boba helms and that's with WOF templates,i may have to give this a go at some point
  12. Formerly SamJ Psammead's Avatar
    Join Date
    Jan 2010
    Location
    Nottingham, UK
    Message Count
    198
    Jul 9, 2011 - Re: Stormtrooper Helmet for under £10?? #12
    That's just brilliant! Good to see your using household items and picked up some filler at a knockdown price. Can't wait to see you finish this.
  13. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 9, 2011 - Re: Stormtrooper Helmet for under £10?? #13
    Thank you all for your amazing words encouragement!!! I'm Gobsmacked! lol!
    ManfromNaboo said: View Post
    Mate, that sounds like a totally brilliant idea, but I wouldn't have a flipping CLUE how to change it! lol!
  14. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #14
    Ahem......I seem to have stumbled onto the right bit that lets you change the title! There's hope for the ol' dawg yet! lol!
  15. Ceric Neesh's Avatar
    Join Date
    Jun 2008
    Location
    Ocala, FL
    Message Count
    263
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #15
    Holy shamolie! Great work so far, I'm really looking forward to seeing it finished! I wish my prop/costume projects could be done on that sort of budget!
  16. Banned
    Join Date
    Jun 2008
    Message Count
    324
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #16
    Ok I'm totally hooked now! Gotta see more.
  17. digger2307's Avatar
    Join Date
    May 2011
    Location
    Edinburgh, Scotland
    Message Count
    193
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #17
    i am loving this. looking forward to it finished. might try yourmethods myself when ur done.
  18. Banned
    Join Date
    Jun 2011
    Message Count
    10
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #18
    although this is a clever build. I do not see that working out for an accurate costume that would do justice to the name stormtrooper. the only way I have seen to make a somewhat movie accurate costume is through pepakura. However this may be great for a Halloween costume
  19. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #19
    Hi All! Thank you all again for the support. I am beavering away, gluing bits on here and there and it is slowly coming together! Your interest and supprt REALLY do spur me on, so keep it coming and I will hopefully post today's progress pics on here this evening
  20. Protocol's Avatar
    Join Date
    Apr 2010
    Location
    Oslo, Norway, Norway
    Message Count
    51
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #20
    This is amazing! Love builds like this! Really show the power of a little imagination, and a whole lot of will! Again, LOVE it!
  21. Banned
    Join Date
    Jun 2011
    Message Count
    10
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #21
    I know you're not trying to make it accurate that much is clear.That's why it would be great for Halloween. I'm having a great day I feel like I could blow up the death star
  22. 3jack's Avatar
    Join Date
    May 2011
    Location
    North Wales
    Message Count
    190
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #22
    Holy crap, for the budget and supplies that looks amazing mate. I never failed to be impressed with peoples building skills on here but to take a bunch of house hold crap and make it look THAT good blows my mind.
  23. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #23
    Hi All! Well, here are the pictures of today's progress!
    I started by cutting and fitting the half discs for the lower side tubes.
    I then started to form the two "eyelids" that are situated either side of the vocoder.
    In this one, you can see the new technique I have started using to try and give better support to the Paper, which can sag a little in places. It seems to work well.
    I then made good over the top with papier mache to form the right shapes.
    This next pic shows the bloomin' nightmare of trying to sculpt the front Jowls that house the pods and mic tips. Cardboard doesn't like bending in more than one direction at a time!
    I finally achieved the right shape by building a lattice of thin strips of card, as I did on the lower side tubes. This worked really well and I will post some pics of how it looks, when I do the other side tomorrow. The papier mache is a little uneven, but I will go over it in white paper before I bondo it.
    This view from the front shows what an absolute PIG of a shape this is to recreate, but I am happy with the overall result. The Pod where the mic tip goes is possibly a little too round, but I guess that's the price you pay when sculpting with bog roll tubes! I can live with it...
    Last pic for today.....the helmet looks really tall in this one but I think it must be the white causing an optical illusion as I have rechecked my measurements and they are all checking out fine!
    I hope you enjoyed today's installment and I'll be back tomorrow the another update! Thanks again for all the wonderful support Guys!
  24. doc is offline
    doc
    RPF Premium Member doc's Avatar
    Join Date
    May 2010
    Location
    cali(upland)
    Message Count
    137
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #24
    Lol that's so cool
  25. Join Date
    Jun 2011
    Location
    UK
    Message Count
    1,114
    Jul 9, 2011 - Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP #25
    doc said: View Post
    Lol that's so cool
    Thanks Doc
Similar Threads
  1. Stormtrooper Helmet Build (With a budget of $20)
    Darth Reivax, Replica Movie Props
    Last Post: Feb 5, 2013, 11:01 AM
  2. Replies: 5
    Last Post: Jan 13, 2013, 9:03 PM
  3. Replies: 27
    Last Post: Sep 25, 2012, 3:25 PM
  4. First Build: ANH Stormtrooper Helmet FINISHED
    TheOrdner, Replica Movie Costumes
    Last Post: Sep 23, 2012, 9:44 AM
  5. Replies: 119
    Last Post: Jan 29, 2012, 9:06 PM
1 2 3 4 5 6 7 8 9 10 11
