Zabana
You could reduce those to about 10, since 50 of them are the same image just rotated slightly but not enough to see anything different.
It was easier to take them all and left him do the choice :rolleyes
Well like someone else pointed out, it seems theres a rubber 'bootie' in there, probably fit around Robert Downey's foot, with pipes and tubes and stuff molded in. You could start by figuring out those dimensions and work from there.
witch piston connectors are use ?Hello everybody,
I am currently researching another Iron Man project: Tony's Repulsor Boot.
http://www.hollywoodhardware.de/board/08.jpg
I am especially looking for the large object on the backside of the boot and all the little piston connectors. I am pretty sure, the large thingy is a found object. I browsed the net for animatronic piston connectors, but so far I had no luck.
I found some comic con 07 pictures of the original boot, but if anybody has additional photos of the prop, I'd appreciate those.
Cheers,
Thomas
look at my image. it most likly is from a car.
it's OEM Harley-Davidson VRSCD rear brake master cylinderBased on the second photo, I would say it is a rear brake master cylinder off of a motorcycle that uses a remote reservoir. The nut, at the bottom, with the loom coming out of it is the brake light switch. Maybe off of a sport bike.
I looked around but cound not find any the had angled ports. I also found some proportioning valves that are similar but still no angled ports.
