MonsieurTox
Re: Y-Wing Parts Map for the "Green Leader" Project
Wow and pictures of the bottom! Great find!A ton of good pics of the EFX gold leader proto here. Pages 3 through 7. Might help with ID'ing: http://picssr.com/tags/propreplica/page3
You're correct sir !
Did you get my PM?
Sent from my SM-N915W8 using Tapatalk
Is that bit, in the middle of the 8 rad part, from the harrow? It looks like a train part.
Thank you for the help! I had received the Saturn and Kettenkrad in a PM, but hadn't noticed the Nichimo gun barrel as the thin part inside the hull. You can even see where they filed off a piece of the barrel for it when compared to the original kit piece! I'd like to thank you for your original Y-Wing thread which goes as far back as 2001 on this forum! I found that thread very helpful. Too bad the whole thread wasn't transferred when domains switched! Would someone be able to share an image of the Mustang piece that belongs inside the 8rad hull? Is it just one large piece that goes there? I have not found a scan of that kit yet. Here is this updated map for the moment!Far right unhighlited part within the 8rad hull is from Saturn V. The thin horizontal thing is a MG-34 barrel from any number of Tamiya 1/35 armor kits. The round disc is from the Kettenkrad, IIRC. Within the highlighting on the 8-rad are a couple of added, tiny little clip-like parts, shaped like )=(, from the Nichimo Jagdtiger. (EDIT: I think you already observed that) This is from memory, I have this written down somewhere and will contribute further within a couple days.
