Whats the issue? im a lil worried when I get to them about the scaling.the thighs are kickin my A$$!
I'm building a mark VI suit and have hit a wall with these thigh pieces :angry
The back is next and looks epic hard, did you use the same scale as the chest piece to make sure it all lined up? Thats the only way for them to line up right im thinkin.I don't do the fiberglass way anymore, but the hardest part was doing the back piece(mark 7)
Other than that foam is really easy
Thanks for the confirmation!Yes the back and chest need to be scale the same that way they join together symmetrically
I found if you build each piece in sections rather then a whole it fits together better. I used to start at one point then work my way around until it was finished, but I found that way can disfigure the piece. One mistake will get amplified as you keep going. For example on the back I made the shoulder parts first then set them aside. Then I made the left side set it aside. Made the right side, then the middle. After each piece was build separately I would then glue them all together. This really worked for me so I just thought I would share.
Have fun!!
you mean pep them in sections right? To be clear you would still resin it all together as one piece? Btw your build is coming out awesome cant wait to see more pics.
Have fun!!
Yeah pep them in sections, you resin them all together. Thanks, I have made a lot progress on my build. I was just waiting till I had a bit more done before posting some pics.
