RegularGent
Toothless Quadsuit
Hi there!
As a huge dork i've become obsessed with the idea of a Toothless costume. Last year at the Adelaide Comic Con there were fairly basic versions of him as a jacket or jump suit with pull-string wings but I wanted to create something a lot more complicated.
To start with I've drawn up sketches of what I envisioned the suit to look like:
I've planned to use a PVC pipe to connect the head to a backpack type strap set on my back to keep everything off my head and neck. The backpack will also be the running track for the articulated wings. That's right, I'm making the whole thing work.
Gosh, this'll be difficult.
In the top design I drew the wings attached to my thighs so if I stood the tightening wiring would cause the wings to expand. Since then I've dropped that idea and made a new one.
But wings later, back to the main structure.
The head is planned to be able to freely move up, down and left to right. To start with I have to plan for a hook Whether i use brackets welded at certain angles or a ball joint for the movement I'm not sure. Any ideas would be awesome.
The tail will start off as PVC so it can bolt to the backpack but will ultimately be fabric and Plush Toy stuffer I think, although a strip of furniture foam might be better. I'm not entirely sure.
Now, the making part
HEAD Pt.1
I began buy purchasing a roll of chicken wire and a roll of malleable wire from Bunnings. I then set out to shape Toothless' head. I gathered as many reference images as possible and began to do that thing called MATH.
Using ratios i figured that full sized dragon would be 8 metres long. I, however, didn't fit the required amount of length in my torso to accommodate that, so i re-calculated to make Toothless only 3 meters long.
I started shaping the head with the chicken wire and other wire and found it much more painful than i expected. Wire is pointy. Take notes people. so after around two and a bit painstaking hours i finished the head and decided the placing for his eyes.
The next post will have the head base being foamed and my wing design.
Cheers guys.
