TMP Iron Man Wall display..
TMP
This is a project of Ironman were it looks like he just busted trough the wall. The design only reveal front and one side of the armor. Therby a bit less cost involved.
The "rubble" and loose "Concrete" arround Ironman penetrating will be in primed material. The only painted will be Ironman..
The reason for the "rubble damaged wall parts" are primed is because this way i can match the color on the wall in the room i want to display it. And this is 1:1 Scale... It also invloves hiding a power wire inside the leg and so it can connect directly in a power outlett on the floor so it lights up.
The entire setup will have a Hangers on the back so its only to drill holes and place screws in the wall and put it up.
What do you think?
http://i590.photobucket.com/albums/ss349/Timelessmovieprop/P1060302-1.jpg?t=1263591186
This has got to be the best Iron Man display idea ever, would love one of these ... if i had the space that is.
I had the same idea I wanted to do with a life size hulk coming through, I think it would look great looking forward to seeing any pics
sadly this idea never saw the light. But if anyone ever wish to comission something similar we are up for it :D
I second the "brilliant idea".
An exihbit at Tate modern showed a picture of a shed about to explode.
The wooden sculpture was all the splintered pieces split second after explosion hung by wire from ceiling.
The hanging wire stuff detracted from it so keep with mounting from behind.
Cheers
