RedTwoX
I would like some help tracking down a base on which to make The Mirror Mask. Unfortunatly I don't have the ability to take screen captures. I know that will make it difficult for you good folks to help me out :unsure Perhaps someone else would be kind enough to catch a screen cap or two? The mask is never really show very clearly. It's also highly reflective (it is the Mirror Mask after all :lol ) and is lit to obscure it. I'm sure they did it to add to the mystical nature of the mask. While the lack of a good, clear, detailed image will make an exact reproduction difficult (unless someone manages to get their hands on the screen used prop), it does open this piece up some artist license... and I'm just fine with that.
Since I don't have pics, I'll try to provide a reasoinable description. This is a full face mask, from under the chin to above the forhead. The sides stop just before the ears. The facial features have been idealized and sharpened. The surface is perfectly smooth with a silvery, mirror finish.
I do not expect to find this mask. What I hope to achieve is a base that is as close as possible to reduce the amount of time and effort that I will have to put into "resculpting" it.
Here's what I've found so far:
http://www.halloweenstore.com/Merchant2/me...ct_Code=1116-01
http://www.starcostumes.com/item.asp?item=CR1116%2D02
http://www.starcostumes.com/item.asp?item=CR1116%2D01
The first two might even be the same mask just from different resellers, so that isn't much to work with thus far. The first actually isn't a bad starting point. It has a good sharp edge at the eye brows which can be made even sharper with a little putty work. The forehead is much too low, and it will be tricky extending that compound curve.
I know this isn't a lot to go on. I'm hoping enough of you have already seen the movie to help, and perhaps someone could assist with screen caps.
Thanks for taking the time to read, and for any help you can provide in finding a good base mask to work from.
David
Okay, hopefully this will help some. The Quicktime movie trailer was still online, so I took some caps from it. They're small, but a lot better than nothing.
The top two give a good look at the sharp edge along the eye brow. The third pic shows the height of the forhead and the sharp edge of the nose. Any help in acquiring a base mask for this project will be greatly appreciated.
David
