Soylent Green, Red, and Yellow Labels
OzReturner
Going off of RobertJ999's Soylent Green promotional can label, I modified it to be accurate to the actual prop. It is now double sided, and has the proper MGM credits on the side, with his recycling logos being removed.
In the same vein, I wanted to also have a can of Soylent Red and Soylent Yellow, as though those were also produced products with the same look. These are not double sided because of the size of the plant decorations, but do retain the MGM credits.
These labels were sized to fit a Nestle Nutrament can, which is an accurate size of 4 3/4" high by 2 1/2" wide. You can still buy these online. I found mine in the ethnic aisle, of all places, at a local Wal-Mart. The cans do not have a plastic lid, nor a prop accurate pull top, similar to a can of oranges, but a beverage pop top. I plan on looking at fish food cans to locate a clear lid that will fit.
The wafers are painted balsa wood with a slight bevel on the top. I guessed at the dimensions from research I did, assuming them to be 1 3/4" squares, 3/16" thick.
Next post to have the label images
