pandatrooper
Hey guys, I'm going to be sculpting a few objects with high density carving foam (the taxidermy type).
I've done some work with pink foam before, with success. However, I find that with clays, I will often add material if I've taken off too much during shaping / sculpting.
The question is: for foam what do you use if you've "removed too much"? With pink foam, I would often spray some injection foam insulation on top, let it cure and cut off what I needed. But of course the injection foam tends to be "holey" and needs additional finishing, with plaster or whatever.
Any other ideas for fixes to higher density foams?
Thanks!
Thanks!
