allosaur176
Hey guys
I had received a UC Shards from a member here, and unfortunately he did not know the tip of the blade on the hilt was broken off and missing...I can return it with no problem, but I've wanted one of these for a long time..
My question is, do you think it is salvagible??? Can it be ground down to a point and still look good on the display???
I know if I grind down the tip and edge a bit, there will be an obvious piece of the shard missing..
The only way I can see this working is if the whole blade was ground down, then have the mount lowered to line up properly....
any idea's?? Is anyone here capable of doing so?
