Terrasolo
Hello, I've been trying to ID this Mini CD case, which I'm aware could be a combination of two or more, but the case itself - minus the tray - is causing me some issues. It would have aired in March 2000 so the disc and case would have been a 90's era item.
What I can tell is that the case is smaller than a regular CD jewel case but larger than modern mini CD cases. It has no ridges on the sides of the case but it does on the top. It also seems to be taller than a regular CD jewel case, although that could be a trick due to it's smaller dimensions otherwise. Also, the case enclosure seems different than normal jewel cases.
In the show it's used as a data disc, which really doesn't mean much I suppose, but I was curious if ay computer experts may recognize the case itself or if I may even be wrong about the mini CD.
The other thing that gets me is the disc tray itself, the Mini Disc sits recessed into it. If they tray were meant for regular CDs than the tray would just be flat there, not recessed to hold a small disc.
So that's it, any help would be greatly appreciated. Thank you all in advance!
