P2 Mask Redue
Biggdaddy
How do you start a mask over. I want to do a repaint, but don't know how to get the old stuff off. Help.
What is it acrylic? Gonna find that difficult I think. Not something I would personally attempt. Can't you just paint over it? I would get wet and dry sand paper and rough up the top layer and just paint straight over with a base coat. No need for a primer.
If you're talking about a latex mask it's easy.  Scrub it in warm soapy water with a soft yet still some what stiff bristle brush.  I've also heard of people using some sort of mild citrus cleaner to help remove the paint as well, but have no experience with it.  The main thing you want to be concerned with is removing any loose bits of paint.  You don't really need to worry about removing all the paint.  Once that's done, coat it in whatever you're using as a primer coat (prosaide, etc.) and go from there.  Just curious... what did you use to paint it with?
Brian
Thanks fellows. It's latek mask, latex under coat, then ink. I will try the soaking and scrubbing with our soft scrub brush.
