ORVILLE medical Scanner.
BrundelFly
Im on an ORVILLE kick, as Im excited about the upcoming 4th season. (no, it is)
Anyone have any reference pics besides these?
I had done an exhaustive search for the USB hub that was meant to be the base item for the scanner but no dice.
I have made a 3D model but without accurate dimensions I don't want to have the prop resin printed yet.
I do not have any special knowledge of this prop or the display, but I did some analysis of the image provided. The “Claire's Medscanner” text “may” be 38 Point Italic text. Based on this, and removing the distortion, the foam board it is printed on is 8 mm thick - which is a standard size for signs.
That make the card 13” x 9.5” and the “white circle” element below the sign is exactly 360 points or 5 inches in diameter.
With less confidence I measure the clipped gray rectangle which surrounds the black field – on the white device above the card – to be 190 x 285 points.
These are my best estimates but you should attempt to verify or cross-reference these calculations with other sources.
Just finished my "Kaylon whip" Season 3, Episode 7: “From Unknown Graves.” This file was made by one of the RPFers here, the EXTREMELY talented, Sylu3Design It is INSANLEY accurate, as I had reference pictures of the screen used one.
You missed that episode? Its called: "Season 3, Episode 7: “From Unknown Graves.”"
