Hey all you Fine Molds Falcon builders...
I've decided on using the FM Falcon as my reference model for scaling up to 1:1. I'm ordering one from Starship Modeler but it won't be here for a week or so.
In the meantime...
I'd like to get started on some rough foundation dimensioning, and was wondering if one of you guys who has completed assembly could pull a few measurements for me so I can get my scaling calculations going.
I need the following measurements:
--- Absolute overall length nose to tail. From the very tip of the mandibles to the back-most protruding edge of the rear exhaust section.
--- Saucer section diameter.
--- Landing gear feet dimensions. I need to know the length and width of the widest points of the foot pads (I assume they are all the same) (A1, A2 on drawing)
--- Rear landing gear foot to foot spacing. I need to know the distance between the two feet that form a rear landing gear pair where one foot is just ahead of the other. (B on drawing)
--- Front to back landing gear distance. I need to know the distance from the front tip of the front-most single landing gear foot to a point bisecting a line between the rear-most points on the rear landing gear pairs. (C on drawing)
--- Distance from port rear landing gear to starboard rear landing gear. I need the cross-beam distance between the outer-most points of the rear landing gear. (D on drawing)
--- Distance from port middle landing gear to starboard middle landing gear. I need the cross-beam distance between the outer-most points of the rear landing gear. (E on drawing) This might be same as D.
--- Distance from front tip of front single foot to a point bisecting a line between the rear-most points on the middle feet. (F on drawing)
--- Distance from front tip of middle foot to the rear-most point on the rear feet. (G on drawing)
Thanks.
I really appreciate any help that anyone can provide.
In the meantime...
Thanks.
