gannikus
Member
Hello I am a total beginner and I sort of have an idea of what to do with foam costumes.
I followed this tutorial TUTORIAL - Painting Foam Costumes - Part 4 of "Using PEPAKURA for FOAM Costume Building" - YouTube
Ok so if I just wanted the foam hands/gloves, will I have a hard time for the fingers? The foam costumes seem a lot easier than the other method.
Will I be ok as long as I use a heat gun to make the foam more flexible? May I use a blowdryer instead?
I have no experience in soldering but I can learn, what is the easiest way to put an led light on the gloves?
Any other help will be appreciated, thank you.
