So I'm working on a Joe vs the Volcano lamp. For those that don't know, the lamp shade rotated and the lamp also played a "music box" melody. I found some small slow 110v AC motors (I think 2 rpm should be fine to replicate the slow rotation in the movie). Can I splice the motor wires directly into the 110v lamp wires or will that short something out? Also, does anyone have any suggestions for the music? I found some small MP3 breakout boards that can play sound from a microSD card, but the board requires roughly 3v DC. So I'd need some way to invert 110v AC to 3v DC. In a very small package...
Any ideas? Or does someone have a better solution than what I'm thinking?
Hey Msisaac, if you're still interested in making this and haven't already, here's a bit of instruction.
Off hand, I would say that as long as your lightbulb is rated for 110v ac, your motor is good to go. It will be stamped or printed on the bulb, but if it's an off the shelf incandescent bulb and you are in the States, it's 110. Which means the lamp cord probably just goes straight from the wall to base of the lamp socket and you can tap both legs of the wire from wherever is convenient for you and run to the two poles of your motor. (I know it's basic, but just in case, if you swap the legs, the motor will run in the opposite direction if you have a preference or are trying to make the direction seen in the film)
As for the sound, do you know off hand what the power consumption of the breakout board is or have a link to a product page? Regardless, it is almost certainly under 3/4s of an amp (750ma) and this product line does what you need in one of the smallest packages I've seen:
http://www.mouser.com/ds/2/468/RACD03-21335.pdf
It's something like 50mm X 30mm x 23mm. Quite small, and it's easy to hook up, same deal, two legs to the lamp cord and noting the polarity, two legs to your breakout board. I'd probably use a volt meter if you have one to confirm voltage and polarity. And
Mouser carries the full line for like $10.50 each.
Hope that helps!
