I see a huge amount of work that people are doing going towards the armour...
But I'm very curious as to why it *seems* NO-ONE has made any kind of attempt at an accurate body-suit? Is it because of lack of reference? Or because too much of the "would be" undersuit material is hidden by the armour. (Even then, no-one seems to try and get the stuff that is visible).
Just venting my frustration, and showcasing the beginning of my own remedy.
I'm starting with the neckseal. Easy enough... It's made from a fabric-backed rubber that i found at a materials surplus store. The exact title of the material or manufacturer was un-marked.
The rest of the suit I will be making with a black pleather that resembles the in-game texture... using a variety of techniques. I will be incorporating the armour straps directly into the bodysuit. Once the armour is completed I should be able to simply clip it on and off with backpack clips.
I am doing the bodysuit First.... so that when I make my armour I will be able to "hone" the two in to create a seamless look. The armour should also match the look and texture of the Legendary helmet (as seen) when it's done.
I will not be using pepakura, I will not be sculpting it or molding it. I will be making my base from a mixture of foamies and ABS plastic. I'm confident when the whole thing is done it will look completely accurate. (Comperable to Blue-realm and the work he has done)
This is assuming that my funds continue to come in and I am blessed with enough free time to devote to it
Here is a pic of the neckseal.... the first foray into an accurate undersuit.
