tobor
The ds gun from Logan’s run is one of my favourite Sci-fi weapons, coming a very close second to the star trek phaser (TOS).
Thanks to Nicksdad and Rylo, I now have some beautiful replicas. In the case of the Rylo gun, it’s more than a replica. It’s a working flame gun that’s better engineered than the originals.
I do prefer the film version, but I wanted to have a go at making the TV gun.
The trigger and grips were reshaped. I’m not sure if the sloping sides of the grips are too flat. They do have a slight curve. I did get a second set of grips, so I can always have another go.
A new fin was cut from 5mm aluminium plate. It was stuck in place with super steel epoxy. The epoxy was also used to make the “blobs”. A small hole was drilled into the fin and a piece of wire glued in place. The other end was soldered to the glow plug.
Four indentations were made in the barrel with a drill. These will eventually be painted red, blue, green and white, to indicate the different firing modes.
I cut a washer from black styrene sheet to indicate a compressed O-ring. I did the same for the Nicksdad film version.
My original plan was to fill in the slot on the side plate and make a thinner slot further to the right. But for some inexplicable reason I thought it would be a good idea to angle the edged of the plate to match the curve of the grips, thus making it more comfortable to hold. I instantly regretted this, it just looked wrong, and wasn’t there on the originals. Using 4mm aluminium plate, I cut two new side plates. I actually prefer the slightly thinner plates.
I have a couple of questions I hope someone can help me with.
Should only one of the side plates have screws to fix it in place?
The gap between the barrel and the side plates as seen in the picture below. Was this on all of the TV conversions? I’m in two minds about replicating this feature. But if it was on all of the TV guns then I think I should.
In the picture below of Gregory Harrison holding the gun it looks like there isn’t a gap. This could just be the angle we are seeing it from and the dark shadows.
I’m having no luck finding an ALCO MPA 103 switch. I’ve found nothing in the UK or on ebay. Any help in tracking one down would me much appreciated.
