Gimpdiggity
Hi everyone!!
I'm in the process of trying to make a raptor claw to display. What I have is a model of a 3D scan of an actual velociraptor claw. As such, it's too small to be representative of the raptors that were in the movie, so I've scaled it up 200% and gotten a pretty good print from it.
What I was hoping to hear from you fine folks on RPF is some opinions on how I should finish the replica.
Seeing as the model is an actual scan of a velociraptor claw, it's obviously a scan of a fossil. Due to this, it's got imperfections and dimples and such in what would otherwise be a pretty "smooth" claw.
I've looked at a lot of pictures of modern birds, and their claws are always smooth, sharp, and relatively "shiny." The birds of prey I've mostly looked at have almost universally had black claws, as well.
In shots from the film, when Dr. Grant is showing the young boy the claw, it appears that it is black in these shots as well. However, from my research this wouldn't be the case if it were truly a fossil...it would be much more brown in appearance. From what I have found also, the prop used in the film was relatively smooth...again indicating a difference from what a true fossil would look like.
So...as I build this piece and work on finishing it, I ask you folks for your opinions...should I go for the appearance of a claw that would NOT be a fossil...make it nice and smooth, shiny, and black in color...or should I work on trying to make it as "fossil-like" as possible?
Making an exact replica of the film's prop isn't necessarily my goal...as the model I've printed is pretty different from the look of the claw in the movie...probably because it's a scan of an actual claw...so I'm taking a bit of artistic liberty in my build.
For what it's worth, here is the printed claw after some filler being laid and sanded out.
You can see the areas where the filler has filled in the dimples and imperfections that are part of the real fossil. So right now if I were to lay primer it would be fairly smooth, with maybe a FEW imperfections. If I were to go with an actual fossil look, I'd end up sanding out those areas where the filler has filled in more so that it's down to the base print with only the filler in the print lines.
I also have another Jurassic World piece that is an Indominus Rex tooth...and it's based off the one that Owen pulled out of the hamster ball when they found it, so it's a "fresh" tooth that I have on display...and this is the reason I'm entertaining making the raptor claw look "fresh" as well.
Any thoughts are appreciated.
Thanks!
***EDIT***
Here is the Indominus tooth display. As you can see, it's clearly not a "fossil" looking tooth.
Thanks!
***EDIT***
