Ironman MK III Suit BUILD *WIP *(camera, Unibeam,Leg hinge,air system,smoke,+ more)
Re: Ironman MK III Suit BUILD *WIP *(camera, Unibeam WIP) + much more
fill work yeah... Not working on it today, But will get on it first thing Monday :D
This is really amazing im building a mark 3 at the moment aswell, so inspiring!
Unbelievable work buddy. Nice ...GM
Do some work on the back thighs
So taking a look at the arm section.. gauntlet don't line up... so trying a tube see if I can make it work smoother..
Can't wait to see it finished. Amazing job, should be one of the accurate and best MK III armour ever seen.
Merci :D having a blast building this I can wait lol once its done ill have to wear it lol:) well Im trying thanks again means allot...
brain storming have a few things going to do I think will help out..
this is one so arm on halt till things show up be nice to have it this weekend see how mail flow goes..
moving on knee coming along working on the thigh area it over laps so going to smooth that out,,
fill work.. now let things dry and set sand later on tonight :D
Been some talk on Ironman paint color... Went to the paint shop today to check out the Nissan Merlot and it is dark its a Red Wine which looks good then I look down the lighter color and found a BMW Siena Red which is still dark but throws off the red I like so I looked it up and I now stuck on which one to use... so what would you use.....
MERLOT :
SIENA : ██
I like the BMW Siena Red tbh. It gives enough dark red but still has that light red which actually shows you that it's a red. I think the Merlot Red looks too maroon. Your choice but :)
Same here
Re: Ironman MK III Suit BUILD *WIP *(camera, Unibeam, Body work, paint option) much m
Not looking too bad so far :)
Can't wait for it finished!
Just throwing this out there ...
For the color, you could paint everything the gold base color. Duplicolor Sunburst Gold is what I use for various guitar related stuff. Then paint the red areas with a transparent (candy) red, like Duplicolor Metalcast. This gives you a deeper finish and follows the "throw in some hot rod red" idea. Clear coating will deepen the effect even more. You can do the whole thing with rattlecans and it won't cost an arm and a leg.
If you have a spray rig you can go with automotive urethane and it will be very durable.
I guess ill have to build an iron man if i want a gloss finish armor :(
War machine is matte :(
Keep it up mockle go check my warmachine build when you have some time, i installed the hinges, modified the bottom one :)
Thanks I hope sooner than later :)
I do a base coat in silver brings it out more. I never had any luck with candy always overlaps wrong for me...
I did look great.. you could always use gloss black:p
