Gaz
Hi everyone,
As you can see, I'm brand new here and I'm also brand new to the very idea of costume construction.
However, I am attending a ComicCon event in July this year, and the only cosplay I am really passionate about is Iron Man. Through some random youtube surfing I stumbled across a few tutorials by Stealth, which lead me here. Though I'm daunted by the scale of the project, I'm determined to invest whatever time, effort and money is needed (within reason, obviously!)
I've already started construction on a "new style" Arc Reactor to complement the Mark VII costume, initially based around Stealth's tutorials, and now I'm improvising (now I've got a little confidence). Once I'm comfortable with the AR build, then I'll start on the full armour, probably within the next few weeks.
I've already decided that I'm going to go down the avenue of using modified foam Pepakura templates instead of card. I'm a Mac user, so I'm in the process of getting hold of a copy of Windows to run the viewer software. I've got the files from another thread, but am yet to have a good look at them and understand them. Will the files I have be appropriately scaled (to a 6 foot average build male) as default, or will I have to do a couple of tests to work out the sizing?
After reading around the various threads on here for the past few nights, I've sourced a supplier of Plastazote LD45 in the UK. Most people seem to be using 6mm EVA foam, but some use 10mm. Before I order one or the other, Ignoring the cost difference, what is the difference in the finished product, or difficulty?
My method then would be to seal the foam with 5 coats of diluted PVA, followed by Plasti Dip. Do I need PVA and Plasti Dip, or is it either/or, as I couldn't quite work this out? Also, would I be better off with the spray can Plasti Dip or 'pot and brush' style?
That's all my questions for now. I'll update you and post some pics as and when. Thanks.
