I found that when hunting high for bugs the shot gun pump handle would fall down the gun. found out how to cure this.
1: remove the 2 fixing screws that hold pump handle in place.
2: slide pump all way back.
3: cut a small peice of sticky velcro soft part. I used white as thats all i had.
4: slide pump back and forth to see if the velcro can be seen.
5: slide pump back to the place to refit screws. tighten with care.
pump now stayes as the top
