Finally finished my Aliens Pulse Rifle
jhusel
I picked up the Airsoft Pulse Rifle kit from an RPF member in a trade. It is a great kit! It has injection molded plastic parts that lock up nice and tight! I love how tight and solid it mounts up. Being molded in the correct color is awesome too, so no painting required.
The counter is sweet. When the clip is removed, it lights up as 00. When the clip is installed, it lights up as 95. The coolest feature is that it counts down as you shoot, per BB. That is awesome! I also really like the pump/shotgun feature. It has an aluminum sleeve in it that closes, hiding the grenade. Then you rack it back and it exposes the grenade. Now it didn't come with a grenade, it came with a plastic shotgun shell. I replaced that with an SD Studios grenade.
The stock is an SD Studios piece that I worked to fit the gun. It has a working pin that allows you to move the stock and lock it in multiple positions, which is pretty cool.
I got the sling from Noble, as well as a sweet mag insert for the clip to attach to the mag bottom. I need to take a pic of it.
The shroud is plastic, and the plates are metal that hold it together.
I bought a Cybergun Thompson from Kapowee. It is mostly metal and very heavy! I bought it for $50, as a parts gun. It works, but was missing the charging handle. I called Kapowee, and they are sending me a new one, which is very nice!
I'd like to thank Noble for all of your help.
Sweet build Jason, looks great, i'm gonna be woking on my second today, makes me wanna start even sooner!
Thanks guys! You are a funny man PHArchivist!
Yes, the stock is retractable with 3 locking positions. This is the middle setting.
My my pulse rifle has sd studios barrel vent and stock with an airsoft m870 in the grenade launcher held to the Thomson with custom aluminium bracket. The battery for the Thomson is squeezed in behind the shroud.
