Hey all. Need some help id’ing the led / lamp bezel in the top of the presidents phone. I’ve searched and searched and can’t find it. Has anyone sourced it?
The white bezel makes me think it is a single LED designed for making your own Vue meters.
Digikey carries three LEDs that fit this style. See this link.
They look like this. They have no part numbers on them so i cant help with that. You have to sand the LEDs down to get the same look that the prop has. Right side is unmodified. Left is sanded down, probably a tad too much. Send me your addy and these 2 are yours if you want them.
They look like this. They have no part numbers on them so i cant help with that. You have to sand the LEDs down to get the same look that the prop has. Right side is unmodified. Left is sanded down, probably a tad too much. Send me your addy and these 2 are yours if you want them. View attachment 1297435
Same style but the multipass are larger. Same series of LED though. It is the same as the yellow LEDs that is used on the Han in Carbonite panel that has the Bronica hood. There are a bunch of yellow ones in the hood.
Order today, ships today. SSL-LX4673ID-LA20 – Red LED Indication - Discrete 2V Radial from Lumex Opto/Components Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Order today, ships today. MV57124A – Red LED Indication - Discrete 2V Radial from Everlight Electronics Co Ltd. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com.au
DigiKey is a big global distributor, so you should not have any issues sourcing the LED from them
Hey all. Need some help id’ing the led / lamp bezel in the top of the presidents phone. I’ve searched and searched and can’t find it. Has anyone sourced it? View attachment 1297181
Hi
I used to own the hero phone from the movie, and if I recall correctly it was not a LED or anything functional. They had a styrene sheet cut with a blade, and it was a red vinyl piece, also cut with an exacto.
It was all done kind of sloppy, and never thought anyone would look at these small details
